I keep getting a message flash up in my phone saying the headset is not supported change headset or go to sony support page but couldnt see anything. Anyone have any idea what it could be
I've got this same problem and it's so frustrating! I've been getting the ''Headset not supported'' message since the beginning of January even though I don't have a headset plugged in. I've cleared data and uninstalled updates (Smart Connect) and eventually decided to disable the whole app since it didn't help. I've tried restarting the phone and I've checked the audio jack (where there's no dirt/dust to be seen). I can no longer talk on speaker because the phone pops up the message and turns off the speaker. I'm really hoping that Sony fixes this problem ASAP because my phone is becoming pretty much unusable because of this. If we're not getting a software update that fixes this, then I'm afraid I'm gonna get a new phone and this time it's unfortunately not gonna be Sony (have had tons of problems with my Z1 Compact and the acro S which I had before the Z1C).
I'm also getting this error since last week, no headset connected at all. Nothing helps. Xperia Z1.
As workaround helps disabling Settings -> apps -> all -> Unsupported Headset Notifier
