Call ended problem
Mohamed11
Visitor
Call ended problem
I tried every thing ( factory rest.sim changed.all app updated.network area changed) smart solution please
20 REPLIES 20
Mohamed11
Visitor
Problem solved thank you all
michael_patzek
Visitor
Mohamed11, how did you solve the problem?
Zuhoor
Visitor
How did you solve the problem?
Mohamed11
Visitor
 the problem caused by sim company not by sony
Zuhoor
Visitor
I tried the sim on another device which works well ( successful calls)
Raghu5
Visitor
Myself also facing this same problem for more than two days in airtel network. Customer care also not giving proper solutions.I don't know what i do.
Can u help me,how to resolve this problem.
Thanks.
Jibber
Visitor
I finally found the problem. The night before I had set my phone to 4G only in settings.
It must be set to 3G and or 4G.
You can now make phone calls
haryop
Visitor
thanks. I had same problem and change mobile network setting (4G(preferred)/3G/2G) , and I can make call again
Karinaa
Visitor
change ur phone setting by dialing *#*#4636#*#* select your preferred network
Nita4
Visitor
What if call ends immediately after dialing only one particular number?
