- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I moved from my Z3 Compact to the XZ and cannot find the option where the ring tone has the option to escalate the volume like the Z3 could? Has this been removed under the XZ?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There would definitely be third applications that supply this type of function, it would be more of a trial and error to see which ones work the way you want them to.
Good luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @TheBigLebowski,
Welcome to the community,
I can advise that increasing ringtone has been removed from the later Android versions. I cannot advise as to why this has been removed however.
I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the prompt feedback. Just as info if others ask, I have seen there are several apps, i.e. "Escalating Ringtone" which would support that function.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
can i extend the incoming call tone i only 6 rings o4211
