adjusting the volume of the notification will defeat the purpose of the Do not disturb function, that is why when you try to adjust the volume even a little the DND will turn off.
Hi @Alexie,
Welcome to the community!
It sounds like you are running Android 6.0 in your phone.
Just to clarify, you mean that Do Not Disturb is disabled when increasing the volume? As @nolramlb mentioned, increasing the volume even a little will disable the Do Not Disturb mode.
Just for fun I also tested this in a phone running Android 7.0, there I was able to increase the volume without disabling Do Not Disturb.
I hope this helps. If not, let me know!
My phone is in silent mode but after a while the sound will automatically turn on
