- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
February 2017
February 2017
The USB option ONLY displays for a split second when you disconnect and reconnect the USB cable. When it does, you have to be lightning fast to change the USB setting to Transfer Files, which when selected doesn't change anyway. It does enable you to transfer files to a PC but doesn't change the setting so you can update your phone software from your PC.
This is a another bug in the XA Ultra.
Solved! Go to Solution.
10 REPLIES 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2017
February 2017
Yes worked, thanks.
- « Previous
- 1
- 2
- Next »
