Battery usage statistics only shows data for display, no apps are listed. Also display statistics are show not from last 100% charge as stated but from last reboot only. How can I enable proper statistics?
What you see in statistics is what has been using battery from last full charge and it has to be above 1% of the used battery percentage. Your screen (ekran) has used 97% of 33% used battery. Other apps or services that were using battery have used below 1% and that's why they are not displayed. Charge your phone to 100%, leave it a couple of hours than go to battery and check what is showing.
