Some system apps are missing after reset
Wasim3
Visitatore
I updated my phone with January security patch, after some days I opted for reset as the battery was draining too fast but post reset I noticed that some systems apps are missing not only Sony but also Google apps like g+, keep, play games etc. Don't know why? Could someone tell me why is it so? Thanx!!
19 RISPOSTE 19
Jonas
Master
Hi @Abdullah4,
I'm sorry to hear about that, it does sound very strange. Slightly_frowning_Face
When you reset the phone, did you perform a software repair using Xperia Companion or was it a normal factory reset from Settings > Backup & reset?
If you go to Settings > Apps > tap on "All apps" > Disabled, are any of the apps that are missing in this list?
If they aren't, I would recommend that you perform a software repair using Xperia Companion. This will delete all data on the internal storage in the phone so it's advised to backup using Xperia Companion before starting with the repair.
Let me know how it goes! Slightly_smiling_Face
Wasim3
Visitatore
Brother, when I tried software repairs it say's "modified secure software detected. This unit cannot be re-flashed with Sony software. Please return unit where it was purchased.
Error code:UEGetPhoneInfoXCSDevice
UE_2006.
What nonsense is this? I have recently purchased this phone it's just 1 and half months old and it started creating problems.
I don't understand why can't you people make a stable smartphone when you are charging premium amount for your device.
Your software optimization is as pathetic as your service centre, now I have to look out for a service centre and there are hardly any few here where I live.
Seriously, if this is the way you people make your products then I have to seriously think about it, before buying any Sony device.
. . . . . . Thank You.
Jonas
Master
Hi again!
This error message will be displayed if Xperia Companion detects that the device's software has been modified in some way, not necessarily rooted only. Have you perhaps unlocked the bootloader on your device?
Keep me posted!
Wasim3
Visitatore
Brother first of all I didn't unlocked the bootloader neither my device is rooted everything was fine until I reset my phone. I dialled *#*#7378423#*#* and in the rooting status section it's shows 'Bootloader unlock allowed:yes'.
And I am sure there is no error from my part.
Wasim3
Visitatore
Can you please tell me the solution or what I have to do?
Jonas
Master
Hi again!
I'm so sorry for the late reply. Slightly_frowning_Face
This is being looked in to and I will update you as soon as I have received more information.
I'm sorry for the inconvenience.
Wasim3
Visitatore
Ok
Jonas
Master
Hi again!
Have you managed to repair the software in your phone yet, or are you still receiving the same error message?
Let me know if it worked to repair the software and how it works after that!
Wasim3
Visitatore
No, it still showing the same error message.
Just wanna know if I have to go to a service centre for repair or there are other options to solve this issues?
A quick reply will be appreciated. Thanx
