How to make phone silent
Jimmynewton
Visitor
Can somebody explain to me how to put phone on silent I had the widgets to drag down from top right but they seem to off disappeared
1 REPLY 1
profile.country.US.title
Qatrium
@Jimmynewton
The silent mode is called "Do Not Disturb" on Android 7, you can activate it by:
- While your screen is active, press and hold volume down until vibration mode is activated, press once more for silent mode.
- While your screen is active, pull down the notification bar and tap on "Do not disturb" toggle.
