there's an issue (lag? slowly playing?) when playing any video (using stock player or mx player with hw decoder) with those encoding details
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Writing library : x264 core 148 r2762 90a61ec
any video with other than those is fine
and yes i've tried software repair, factory reset and safe mode still the same.
same videos played without any issue on Marshmallow, so any idea to fix this? (sorry for my english)
EDIT: the extension of all videos which is lagging is MKV
hey guys!
i had the same problem and i couldn't watch my movies with MKV format.. because it was playing piece by piece (both the audio and video)
and yes... this happend after that i updated my phone
but i fixed this tonight ^^
i advice you to do this
download the new version of mx player... then play your video and touch the buttom below which includes the signs : SW / HW
after that choose the HW + in the menu... i hope your problem will solve too ^^
check this photo:
https://drive.google.com/file/d/1c9I-3OM0kzuV0WVNGmsUVHyv1Gbcq60s/view?usp=drivesdk
sorry about any wrong grammer ^^
Well thanks but unfortunately Sony's built-in equalizer doesn't work with any 3rd party apps.
