Comparte tu experiencia!
How do I get the original wall paper back if I have chaneged it to one I have uploaded ?
¡Resuelto! Ir a solución.
Hi streffie
To do this
- Press and hold your finget on a home screen
- Tap "Wallpaper"
- Scroll all the way to the right and you should see the orange wallpaper ready to be used again
Hope that helps
Thank you, thats spot on
do you know if you can delete empty pages, eg the ones left to right of the main app screen ?
