tablet screen
profile.country.en_GB.title
detickl
tablet screen
My Tablet has seized up .How do I clear the screen?
1 ACCEPTED SOLUTION
Thalamus.
Champion
Hi detickl,
Try the following..
Press and hold the power button for about 10 seconds to force it to shut down.
If that does not work then try pressing the  reset button. Insert a pin or other slim object into the reset  button (hole). hopefully this should allow to force your tablet device to shut down..
1 REPLY 1
Thalamus.
Champion
Hi detickl,
Try the following..
