Sony Xperia Z2 watch Netflix offline
Lifetec
Visitor
Hello,
I have a Sony Xperia Z2 and I'm not able to download Netflix series.
The download button doesn't shown.
Android-version: 4.4.2
Netflix verion: 4.16.3
How can I download Netflix series using the Netflix app on the Sony Xperia Z2?
Thanks in advance for any assistence!
4 REPLIES 4
Lord_viridis
Have you checked all these options?
https://help.netflix.com/en/node/55672
Lord_viridis
After looking further.
Apparently Netflix downloads are only compatible with devices certified for HD viewing.
A list of devices are here.
https://help.netflix.com/en/node/23939#netflix-in-hd3
Under "Netflix in HD"
And you can read about download limitations here:
https://help.netflix.com/en/node/54816
Note in the first subsection
"*Android devices must be able to stream Netflix in HD to select video quality. Visit our article about Android for more information about HD-capable models."
Lifetec
Visitor
Hello Viridis,
Thank you for the feedback.
-> Tried all these suggestions; didn't solve the issue
-> Sony Xperia Z2 is certified I guess (I can use the play store)
https://help.netflix.com/en/node/23939#netflix-in-hd3 -> "Netflix in HD"
-> Sony Xperia Z2 is in the list
-> Supported Android version and Netflix version is used
I would like an answer from Sony.
Is Netflix offline supported for the Xperia Z2?
If no.
Why?
Will it be supported in the future?
If yes
How?
SirPix
Visitor
I contacted Netflix who weren't much help. I found once I did a factory reset of my tablet, I was able to use the offline function.
