annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
PS Controller
RÉSOLU
profile.country.en_GB.title
austinman
Visiteur
PS Controller
I saw on you tube that a ps 2 pad can be connected to the table what connection will I need is it a female usb to micro usb  i fing playing Cras a bit difficul so wanted to try one of my old controllers
1 SOLUTION APPROUVÉE
Solutions approuvées
praed0r
Visiteur
I use a dualshock wireless controller myself and have no idea if a USB ps2 controller would work, but to try it you will need a micro-usb "On The Go" adaptor - plenty of choices on ebay and amazon.
Good luck - hope it works for you
Voir la solution dans l'envoi d'origine
6 RÉPONSES 6
praed0r
Visiteur
austinman
Visiteur
just picked up a ps 3 controller I have used  it on crash using a usb cablehow do I set tthe pad up to work wirelessly ?
praed0r
Visiteur
Sorry for the delay in responding to your question, I cannot reply to posts on this forum on my SONY TABLET !!!!! so I had to wait till I was online on my laptop.
If you have the correct f/w on the tablet it will auto-install the drivers when you first connect the controller through USB. It does not install via an apk and does'nt use the normal bluetooth settings in setup.
You need f/w 3.2.1 rev 2 for this to work  (in the UK anyway)
Hope this helps.
austinman
Visiteur
I have this firmware version installed. the  controller I have is not a genuine Sony  item it works  when  in wired mode but not wireless
praed0r
Visiteur
The driver will only "see" a Genuine Sony controller, Sixaxis or Dualshock 3, I don't know if there is a workaround for this (knowing Sony - probably not)
austinman
Visiteur
the contraoller says dual shock 3 on it and bluetooth but still cant find or use it remotely
