Podziel się wrażeniami!
hi
does anyone know how to put a digital copy of a film I bought on blu-ray, I typed in the web address on the cover and it comes up with file not found!!
any ideas people.
thanks.
Rozwiązane! Idź do rozwiązania.
As mentioned, most likely a website issue.
Soemthing I have found which you may want to read before you try to transfer to the Tablet.
http://www.sonypictures.com/residentevil/bonuscopy/faq.html
Most likely, bonus copies as a whole can be downloaded and used on a computer but I am not sure that it will be playable on the Tablet due to the restrictions put in place with the digital rights management. Try it and feedback the results.
Sounds like an issue with the website, not with your tablet...
