Hello Community,
i'm pleased to have been helped out on this forum in that someone told me how I can play media from an external source using a file manager.
Now I'd like to throw the problem out there that... my 500Gb Seagate portable drive starts up when connected and a usb notification pops up! great stuff... but it soon struggles (3secs) and splutters leaving the tablet unable to maintain a connection.
Has anyone else connected something other than a usb stick to it? Is the problem because its bus powered and microusb cant handle it?
I know I need to find something else to test as it might be the ebay microUSB to female USB transformer i've recently acquired.
Many thanks
Solved! Go to Solution.
Hmmmm. That is going to require a good chunk of power and the USB port on the Tablet does not have that much of an output to maintain drives especially of that size. I will give mine a go 320gb to see if there is any change. I suspect it will yeild the same results.
