hi i am the laptop vpceb3j1e but i cant find the webcam software can anybody help me?
thanks
Solved! Go to Solution.
In that case, it is not so simple as the ArcSoft software is not availabe for download.
Have a look at the options available to you in this discussion: -
https://www.sony.co.uk/discussions/message/720840#720840
With your model, I would look at the US option.
Hi mimclar.
Try this: -
Start, All Programs, ArcSoft WebCam Companion 3, and WebCam Companion 3.
HI thanks for replying heres the story my hard drive wasnt working evening the recovery wasnt working so i got a friend to whipe everything the only thing he couldnt find was the webcam software is it possible to have a link for the webcam software please so i can install it please thanks
