Start: only the troubleshooting screen appears... it cannot find any errors and appears to run in an endless loop! (Ignoring and booting Windows results only in a blue, blank screen.
Nachricht geändert durch Steppenwolf68
Solved! Go to Solution.
Hi Steppenwolf68,
Have you tried downloading a Vista Repair Disc and booting from that?
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
You can then try a Vista repair and also check your hard drive for errors.
Hi Steppenwolf68,
