Hello!
My vaio vpcf13z1e is about a year old. Since 6 months back, it has only been good for using as a plate.
So I decided to reinstall the computer. I did, and it worked for 1 week - Yes, I've installed ALL drivers and updates.
Today, I'm glad if I can use notepad to type in. Paint is to exhausting for the vaio vpcf13z1e to handle.
I'm running on windows 7 Home premium.
At first, when the laptop wasn't able to be used - I was mad. But now I see. The vaio vpcf13z1e is the best purchase I've ever done!
Now, I don't play any games any longer, I barely touch my computer. Instead I get more time to spend with my family.
So to everyone that actually doesn't want a computer, and just wants to spend time with the family: buy vaio vpcf13z1e.
Thanks for reading this.
Anyone?
It was not obvious you were looking for an answer. We are users like yourself and it sounds like you need professional advice.
I presume your Vaio is still within warranty. If I were you, I would reinstall the original Sony Operating System and see if that fixes it. Just in case you did not reinstall everything .....?
If not, contact Vaio Support for a way forward.
