Hello everybody,
I have the following problem. I have downloaded and installed all drivers from Sony, but in the Device Manager window the Ethernet Controller and Unknow Device shows the yellow bang, as if it were not installed. I tried reinstall them again but its not working.
My other question is, is there a VAIO Win 7 clean install guide or somethinf else that that suggest the correct driver installation order?
Hi tamvar and welcome.
How are you trying to install these drivers? If they do not have a SETUP file, you may have to install then from within Device Manager by right-clicking on the device and choosing "Update Driver". You will then need to manually point the installer at the downloaded driver .INF file using the 'Have Disc' method.
