Vaio media plus missing ?
profile.country.da_DK.title
Daniel.Skov
Heey!
I have just bought a super cool Sony vaio c-series in a nice green colour !
Everthing is great about it, theres is just one thing i dont understand.. All over the website sony says that they have incredible dlna program to connect your vaio with a PS3 ? So far i have only discovered media go to connect to a PSP ? So i've google a bit and found the program vaio media plus, which you do the trick with PS3 but i cant seem to find it on my vaio ? how come ? and can i donwload it anywere ? is that a fail or have they stopped using the program ?
4 REPLIES 4
rich912
Contributor
Hi Daniel,
As far as I’m aware Vaio Media Plus is still installed on most modern Vaio notebooks.
For my particular model it can be found by clicking Start > All Programs. The location of the executable is C:\ Program Files\Sony\Vaio Media plus – your model may vary.
If you state your full model number we may be able to confirm whether or not this software comes pre-installed.
Rich
Go n-éirí an bóthar leat
Daniel.Skov
I already looked in program files, it simply not there..
My model number is: VPCCA4C5E
By the way thanks for answering so quickly :wink:
rich912
Contributor
Hi Daniel,
Unfortunately the full specifications for your model, including details of pre-installed software, are missing from the Support site. We are hoping that this will be rectified shortly – don’t hold your breath though...
Try calling the free phone number contained in the following link and, as you are thinking of buying this model ;-), ask whether Vaio Media Plus comes pre-installed.
http://www.sony.co.uk/product/vn-c-series/vpc-ca4c5e
Rich
Daniel.Skov
Okay thanks for your time :smileygrin:
