When I press the 'quick web' access button, I get a message telling me I do not have the software installed. How do I reinstall the software?
Solved! Go to Solution.
You can reinstall QWA from the Recovery Partition:
I have the same problem. I installed a fresh windows and i also formated the recovery partition by mistake. And now i tried a link found here somewhere and downloaded the QWA. But after i installed it and pressed the web button i get the same message that it's not installed. What should i do?
Hi Foxtrot_47,
Have you also installed Sony Shared Library and the SFEP driver - these need to be installed before the splashtop software.
Do you have SPLASH.SYS, SPLASH.000 and splash.idx in the root directory of C:\
Hi! I tried this but quick web access was not in the list to restore/reinstall? I used to have this program of my laptop but tried in today for the first time in about a year and it's says it is not installed? Any other suggestions?
