:smileyconfused:: can anyone tell me the details of the memory installed in my VAIO PCV- RX-514 , I know its 256 mb ddr sdram but i need to know the speed etc etc as i would like to upgrade it to 512 mb and therefore want to match whats already installed!!!
Go to crutial.com and search for your model. They are a good price and offer good support.
SPEC FOR SONY VAIO PCV-RX514----
Sony Vaio PCV-RX514 - Athlon XP 2.13 GHz
Type
Personal computer
Form Factor
Tower
Dimensions (WxDxH)
20.3 cm x 37.1 cm x 36.6 cm
Weight
13 kg
Processor
1 x AMD Athlon XP 2600+ / 2.13 GHz
Cache Memory
256 KB L2 Cache - Pipeline Burst
Cache Per Processor
256 KB
RAM
256 MB (installed) / 1 GB (max) - DDR SDRAM - 266 MHz - DDR266/PC2100
Storage Controller
IDE
Floppy Drive
3.5" 1.44 MB floppy
Hard Drive
1 x 80 GB - standard - EIDE
Optical Storage
1 x DVD¦RW
Optical Storage (2nd)
1 x CD-ROM - 5.25" x 1/2H
Graphics Controller
AGP - nVidia GeForce4 Ti 4200 - 64 MB
Audio Output
Sound card - stereo
Communications
Fax / modem - CNR - plug-in module - 56 Kbps ( K56Flex, V.90 )
Networking
Network adapter - Ethernet, Fast Ethernet
OS Provided
Microsoft Windows XP Home Edition SP1
Hope it helps!
:smileygrin: thanks for that thats what i wanted to know, it does mention memory on the instruction disk but doesnt specify the exact one !!! THANKS AGAIN!!
No problem.
Your welcome :smileygrin:
