Vaio laptop model SVS131B12M.
Had been working fine then I came back to it (already switched on) to find this error message:
Platform ID: 00001C9D
Intel (R) AT service provider ID: 5,000
Intel (R) AT supported system lock due to: Disable Timer Expired
Time left to enter password: 360 seconds
Please select one of the following for platform recovery:
1- User Password
2- Server Token Password
Select one of the following options to proceed. ..
At the bottom of the screen it then directs me to the Macafee website for help (but I haven't knowingly activated or installed any Macafee products).
Have tried switching it off overnight and rebooting but still the same problem.
Please can anyone help?
TIA
Solved! Go to Solution.
Hi scoobs2013,
This would seem to be a problem with Intel® Anti-Theft Service Powered by McAfee.
There is a discussion on this issue on the McAfee Communities forum:
https://community.mcafee.com/thread/49993?start=0&tstart=0
Support numbers are also provided somewhere in that thread – I suggest you give them a call...
http://www.intel.com/support/services/anti-theft-svc/sb/CS-032771.htm
Hope this helps,
Rich
Hi scoobs2013 and welcome.
Can you please try to find a valid model number - it will start SVS1311*** or SVS1312***.
The model you are quoting is a chassis type which is shared by several models.
Your model possibly has McAfee preinstalledf when you bought it. What Firewall/AV product have you installed?
Hi scoobs2013,
Hope this helps,
Rich
Thanks Blencogo
Product name is SVS1311C5E.
I'm using AVG Free anti virus and last did a full scan on 31 Dec.
Thanks for your help 🙂
Thanks Rich - I'll check out the Macafee support 🙂
Thanks Rich, this has sorted the problem:-). I'm very grateful to you :-):-)
Hi scoobs2013,
I’m pleased that the problem has been sorted. If you can provide details of exactly how it may very well be of help to other members that encounter the same problem.
Rich
NEVER EVER do not activate/use this Intel Anti-Theft powered by McAfee !!!
I have the same problem with my brand new VAIO SVS-1312R9EB
I was so stupid (trusting Sony Vaio team) that I activated this disease...
And of course it started to live its own life, locking suddenly my laptop at its own activity...
Had a phone call with McAfee phone support, what made me a phone bill of a fortune... I´m not a native English speaker - so get the right veeeery long password for unlock my brand new laptop was about one hour call to overseas priced by mobile phone rate...
NEVER EVER do not activate/use this <profanity removed by moderator>!!!!!!!!
Now it is sitting in my laptop inside.
I had a small hope to get rid off and did "clean install" - lot of work, but after all this hassle this holy <profanity removed by moderator> awakened anyway and locked again my laptop.
So I have forced to live with this <profanity removed by moderator>.
It makes me wonder that my next laptop will not be any more Sony Vaio. The previous 4 laptops were all Sony Vaio, but never happened such a <profanity removed by moderator> experience.
Shame, Sony Vaio...
If anyone wants to contact me, please, my e-mail is <personal details removed by moderator>
How to do a real clean install???
It seems that I can not open a new thread - or I do not know how to open a new thread.
However my simple question is - how can I do a real "clean install" to get rid off from this stupid Intel & McAfee "Anti_Theft" <profanity removed by moderator>???
I´m ready to spend hours with my brand new laptop, to make a real clean install.
I want it to work next 2-3 years without problems...
Please Help me get free from this "Anti-Theft" disease!
Hi hegross69,
Not sure how to uninstall completely but page 21 of the user manual explains how to suspend or cancel the service.
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=3417&DwnldID=22045〈=eng&iid=dc_rss
Rich
