VPCEJ
EXTRA STEP OF HAVING TO CLICK ON NAME ON SCREEN SEEMS UNNECESSARY
WOULD PREFER FOR SYSTEM TO OPEN DIRECTLY INTO DESKTOP
THANK YOU
BARRIE alias BWEP26
Solved! Go to Solution.
Hi Barrie,
Have a look at this tutorial: -
http://www.sevenforums.com/tutorials/377-log-automatically-startup.html
If you only have one user registered on the computer and that user is not password protected, Windows will automatically log on to that account at startup.
If you have more than one user registered on the Vaio, you can choose for Windows to log in the account of your choice by removing the check box 'Users must enter a user name and password to use this computer'.
Hi Barrie,
Good luck on this bud. I checked the steps. It will just be a walk in the park for you.
