David18T
Visitor
grx316mp screen
My screen has recently started becoming really pixelated at times, could it be on the way out?
It's normally ok for up to 15 minutes after boot up and then will just mess up
:slight_frown:
21 REPLIES 21
profile.country.en_GB.title
kee-lo_
Member
I'll give it a try to confirm but i'd say it's definitely a loose connection of some sorts. I dropped the laptop a while back and the speaker cover came loose. The speakers don't work now unless I push down on the speaker cover. Also, if the display is messed up and I push down on the cover, it goes back to normal
I think you've solved your own problem, you're going to have to open it up and connect the display back properly, and it should go away.
David18T
Visitor
Are there any pictures on the net with the speaker cover removed to point out where the connector is or will it be obvious when I look?
David18T
Visitor
Took the laptop apart, found no loose wires, put it all back together and no luck. Got annoyed so thumped the speaker cover and it's been fine since :smileygrin: Speakers still don't work though :thinking:
kee-lo_
Member
Hehehe sometimes small things like hitting it work.
robpaxton
I'd buy a pair of headphones if it was a choice between speakers & screen :slight_smile:
David18T
Visitor
headphones don't work either unfortunately
robpaxton
You don't have much luck :anguished:
kee-lo_
Member
Yeah it's not been very lucky :slight_frown:
David18T
Visitor
Not fussed about sound too much, I just use it for programming anyway
kee-lo_
Member
Ah I see
