Fn Keys on VGN-NS10L
profile.country.en_GB.title
asschana
Visitor
Hi all,
I recentlly just upgraded my laptop to windows 7 from vista, and i cant seem to find any drivers to get my Fn keys working again.:smileyconfused:
Anyhelp would be appriciated emmensily
Tags (5)
1 ACCEPTED SOLUTION
Blencogo
Hi asschana and welcome.
You need to reinstall the Sony Utilities from the download website for your model.
7UPG_Sony Shared Library
7UPG_Setting Utility Series
7UPG_Vaio Event Service
You will find them in the Windows 7 Latest Downloads Section here: -
http://www.sony.co.uk/support/en/product/VGN-NS10L_S/updates
:wink:
3 REPLIES 3
flogger12345
Visitor
Check out for any driver for your keyboard under the support page. Hopefully there will be one availble.
can you see any yellow question mark under device manager? http://imagicon.info/cat/12-13/vbulletin-smile.gif
Blencogo
:wink:
Blencogo
You may also need to install the SFEP driver if you carried out a clean install of Windows 7.
You will find this in the Preinstalled Drivers section on the downloads page.
Thanks Rich.
:smileyblush:
