Sony Bravia
Sony Bravia
The tv worked this morning.  This afternoon, I switched on and it said there was no signal.  I checked the aerial was securely in the wall and back of tv, switched it off then on again and tried Auto Tuning, which found 0 services.  Auto Tuning Range is in Normal and Digital Auto Service Update is On.  What else can I try, what could have happened?  Nobody else had been in.
1 REPLY 1
Now it says "no services have been found" AND " please check your antenna connection", which was the first thing I did, and now it also says "programmes are not stored" where it said "no signal" before, and still "no event information" at the top.
