Deel jouw ervaring!
hi, recently bought a great sony tv but the narrater cane on on netflix and i cant turn it off, i have checked every option on the seettings but no luck.
Opgelost! Ga naar oplossing.
hi, i turned netflix on today and there is no narrater, so for now at least the problem has gone. thanks for everybodys help. mick.
Hi there
There has been a few reports of this - since yesterday afternoon. I have just had a live chat with Netflix and they suggested turning off "Talkback" in the TV settings. Can you give this a go - in my testing it didnt work. But you may have more luck.
Settings > Accessibility > Services > Talkback > Turn it Off.
Cheers
hi, quick update, i just checked the tv settings and talkback is already turned off.
Cool - thanks for the update. Fingers crossed it remains off !
