I have just purchased a new Sony KDL-46W905A today. I cannot get the Netflix app to connect. I click on app and it gives me error NW4-8. I have been in contact with Netflix and they can't even sort it. Internet is fine - just can't connect to Netflix servers. Has anyone any ideas it's driving me nuts
Solved! Go to Solution.
Thank you to all for the feedback - I have clicked the "resolved" button for this topic. I guess if anyone is still having problems, it would seem that its unrelated to this particular issue.
Mine fixed too - just took a couple of hours to bed in.
I hate to sound churlish but it doesn't make me feel any happier about Sony support I'm afraid - I will definitely be looking at alternatives when I upgrade our main set in the summer. Sony need to work hard to make me consider them again.
But, again, well done to the forum who kept the pressure up.
whats the download location of PKG4.421EUA as i cant get it. if i try an update through the tv it says newer version not found even though it says i have to perform thr update thanks
Hi jazz2405
Have you seen this thread by any chance:
http://community.sony.co.uk/t5/televisions/kdl-42w829b/m-p/1644783
Is it the same problem as yours? What model TV do you have?
Cheers
Hi did you get it fixed?
My new KD-49x8505 wouldn't connect until I turned my phone into a hotspot and connected to netflix that way.
Once i had established comms to netflix and watch a couple of seconds of a film i exited netflix with out signing out and turned the phone off dropped that wifi connection and then hit the WPS button on the router and bingo it worked.
I was previously cabled in and will try cable again soon but am just chuffed to be on netflix from the TV rather than having to use the Blu Ray or anything else.
Cheers
Martin
My netflix just cut out. Sony KDL-32W654A. Has been working fine for over a year but now cuts off after about 5 mins of watching. Get nw-2-5 error on netflix servers. Have tried factory resetting TV, rebooting internet connections. It works fine for a bit then cuts out.
