Hello.
My other half's parents owned this TV for a couple of years, and it stopped working all of a sudden about a week back. They decided to get a new one anyway, but said we could have it; if we could fix it, excellent, if not then pop it in recycling.
Turning on the TV at the wall shows the power light, but nothing else happens - nothing on the screen, no sound. Every button on the controller makes the power light flicker, except the standby button, and there's no way to put it in standby mode (though it already is for all intents and purposes). If I turn the TV off at the wall, press and hold the TV's power button for ten seconds then switch back on after a minute, both the controller's standby button plus the TV's power button work to put it in and out of standby. Nothing else actually happens - there's not even a flashing standby light to indicate an error code. The TV is practically dead besides the two lights and the familiar click when the power is turned on and off.
I don't know of a reset code, and I doubt the TV was turned off during an update (it's about four years old). Does anybody have any ideas? It would be a shame to scrap such a decent TV especially when we're currently using a 24" Bush model.
Thanks in advance!
