How do I Select the correct Bravia HDMI input for the SKY box
profile.country.en_GB.title
Kevkinsky
Visitor
I have tried to access the 3d settings from the remote control and it will not show on the screen when on the sky 3d channel.
1 REPLY 1
Catmambo
Contributor
Have you tried pressing the sync menu>TV options> 3D then you  should be able to switch there? I think thats the right sequence from  memory...
thanks
