How do I tune my BraviaHD ready TVto receivefree to air HD channels?It currently recognises the channel when I auto tuneand will play the soundbut no picture.
HD ready unfortunately doesn't mean that it's able to receive HD TV channels, it just means that it has enough pixel to support 720p or 1080i source.
In order to receive OTA HD channels you have to have an HD Digital tuner, and the symptoms you see (audio but no video) demonstrate that your tv set does not have it. Probably it is a set older than 3/4 years because Sony was an early adopter of HD digital tuner on all the tv set.
I'm sorry.
Thanks for that. Yes my set is 5/6years old.I live in France and receive englishchannels via sattelite. Would a Humak foxsat freesat decoder do the trick for me ? My current attempts have been with French terrestial channels via an ordinary aerial and I accept your answer about having to have an HD digital tuner.
Dear jamesandjessie,
if you connect a decoder (sat or DVB-t) via HDMI to your tv you will get the result you are looking for. By the way, since I don't think there is any channel that brodcast to a definition higher than 1080i this configuration will meet the capability of your tv set and you can still enjoy it. The only problem is that you'll have to deal with different remotes (or buy some all-in-one like the Harmony one)
Thank you rooob. I will purchase a new decoder to replace my old one. You have been very helpful.
