- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
February 2016
February 2016
EU firmware in UK tv
Is it OK to install EU firmware on the UK Televisions?
I tried once and it went into the blank screen issue and ended up replacing the TV.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
February 2016
February 2016
When there is a firmware update available for your television you should expect to read the following information on the Sony Support Site firmware update page as the example below:
Relevant Products
This information is applicable for the following TV models:
- KD-65X9005A / X8505A
- KD-55X9005A / X8505A
- KDL-65W855A
- KDL-55W802A / W805A / W807A / W808A / W809A / W905A
- KDL-50W656A / W685A
- KDL-47W802A / W805A / W807A / W808A / W809A
- KDL-46W905A
- KDL-42W650A / W651A / W653A / W654A / W655A / W656A / W802A / W805A / W807A / W808A / W809A /
- KDL-40W905A
- KDL-32W600A / W603A / W605A / W650A / W651A / W653A / W654A / W655A / W656A / W503A
- KDL-24W605A
About this download
- Name: PKG4.560EUA
- Date released: 17/11/2015
- Do I need to update?: Your firmware may already be up to date, especially if you have a new Bravia TV model.
- Benefits and improvements:
- Improves the stability of your TV
- Restrictions: only for use with TV sold in Europe. Not all models are sold in all countries
I think it is always good practise to read about any firmware update prior to downloading it to your product. When your TV prompts for a software update firstly go to here Use the search function to find your product then you can read if it is compatible.
Regards
If it ain't broke don't fix it
