Xperia Pro MK16i/a 2.3.4 update 4.0.2.A.0.58
Uliwooly
Special thanx to the XDA forum and Jozinek
http://forum.xda-developers.com/showthread.php?t=1343568
remember that you and only you are responsible for your phone (I'm not responsible for any damage), if anything goes wrong just re-start the flashing processes
12 REPLIES 12
I wouldn't risk it, I'll look for the kernel
zephyr83
Visitor
thanks so much
if you want ot sideload apps here is how
1st Method
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Don't forget to mark the Correct Answers & Helpful Answers
