Android 2.3.4 4.0.1.A.0.283
http://forum.xda-developers.com/showthread.php?t=1279774
Special Thanx to Jozinek
Android 2.3.4 4.0.2.A.0.42
http://forum.xda-developers.com/showthread.php?t=1312475
and Xperiablog
More pix HERE
Solved! Go to Solution.
I just updated my sk17i but now my lock screen animation is not working?? any clue??
Akshansh
which lockscreen animation? the old crt animation? that's gone with the update, for some reason it wasn't included
up
download FlashTool
http://forum.xda-developers.com/showthread.php?t=920746
or
http://androxyde.github.com/Flashtool/
Install it and you will see 5 folders
Custom
Drivers
Firmwares
Loaders
X10Flasher_lib
take the firmware to the "Firmwares" folder
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
This is an step by step guide
Easier method to install
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
go to settings -> applications -> check unknown sources
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
