Hi.
I have a problem.
In my walkman wt19i on taskbar I have a message "Available system update 4.0.2.a.0.62".
In menu "Phone information >>> Update center" I have this message too.
If I click on this message I have information: "Is only available to install by PC Companion"
Now I connect my wt19i to PC via USB.
PC companion says: "Phone system is current".
What can I do to fix this problem ?
Best Regards
Solved! Go to Solution.
I use SUS. I have reinstalled system.
It's now all OK.
I'm interesting how long time will be working with no problems
I have hope is forever
Thanks
Best Regards
most probably it won't occur again
enjoy
Don't forget to mark the Correct Answers and Helpful Answers
Indeed, glad this is sorted for you. It is a rare error that occurs every once in a while but I have never seen it happen to someone twice so you should be ok.
What are your thoughts about this forum? Let us know by doing this short survey.
The same problem have too few other users (from my local polish forum)...maybe is update server problem...
