i purchased sony ericsson mix walkman wt13i yesterday is getting connected to my mw600 device but the sound cllarity is not good and its not displaying the name of the track playing presently. and my old phone w660i when connected to my mw600 is good with sound quality and it displays the track name too. any solutions to resolve this problem.
there is no zoom n no settings regarding camera. (night mode, timer, etc.)
and zoom in viewing the is not there at all.
can these issues be resolved.
thanks in advance.
Solved! Go to Solution.
Try turning off WiFi if that is on while you're playing music. This might raise the sound quality. Let me know if it does.
I've just tested this and there is no support in Mix Walkman for sending the ID3 info to the MW600. So it's got nothing to do with the profiles, simply not supported in the phone.
They should work with each other. They're listed as compatible but some features like caller id is not always supported though.
W660i and Mix Walkman are two different phones and work in different ways. What works with one of them might not work with the other one.
Have you ever updated the software in this phone? Please do so if you have not and then let me know if these issues still are there.
yeah i updated it n it still have the same problem. my be the id3 tag which is read by the phone is not transfered to mw600.
there is a profile miss match that is mw600 has v 2.0 n wt13i has v2.1 profiles.
yeah now after turing off wifi sound quality is good. ok thanx a lot u were really helpful.:smileyhappy:
