Sony Ericisson Xperia X10 Mini Screen gone black.
Not applicable
hi i bought a sony ericsson xperia x10 mini a couple of weeks ago, works fine but i was downloading live wallpapers from android store and there was one called DIY wallpaper and it made the lock screen look like an iphone one. so i installed it and it asked me if i wanted to change my home screen to the new one and i clicked yes, then my screen went black. I can use the drop down bar but if i click on a notifcation in there nothing comes up on the screen. I can see the start up screen and all that and the unlock screen it all works just no home screen. Ive tried reseting by holding lock button and home button for 4 seconds it resarted but it was the same i could only use the drop down bar. Someone help please?
and one more thing, ive connected to computer but i cant get it to do the usb connect because i cant click it on the phone screen.
1 ACCEPTED SOLUTION
Uliwooly
Don't forget to sync and backup w/ the methods above
11 REPLIES 11
Uliwooly
you can use Update Service but that will delete everything from your phone: mms, sms, contacts, apps, settings
Uliwooly
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
make sure to mark the Correct & Helpful Answers
Uliwooly
for future reference
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
or
let me make it simpler
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Not applicable
but i cant see anything on the screen.
Uliwooly
w/ Update Service you don't have to, install it, run it, and follow the instructions
Not applicable
ok i mannaged to connect it to the pc now what?
Uliwooly
you need to install SEUS first, then run it, once you do so, it will ask you to connect your phone on safemode
Not applicable
how do i install seus
Uliwooly
the link its above but on your PC
