Problem updating my x10 to version 3.whatever
Not applicable
Hi guys. New to the forum. Im having some serious issues updating my software. :smileyinfo:
Ive updated my PCC as it told me to and it recognises the phones connected. But when I clicked on the update is available for your phone and when I try to update my phone its saying that its "unable to install or start phone software update components"
Ive had a look through the forum for details on this but the links for the update service dont seem to take me anywhere useful. Can anyone help at all please??:smileyconfused:
Its sooo frustrating!:smileyangry:
Cheers
Steve
1 ACCEPTED SOLUTION
9 REPLIES 9
try
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
don't forget to mark the Correct & Helpful Answers
once you update to 2.3.3 the Backup & Restore will be gone so try this
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
if you have a lot of sms/mms the backup & restore will take forever or might not backthem up corectly
both apps above Backup SMS +    and    backup & restore SMS are great, this last one it's really fast
let me make it simpler
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
after installing Update Service, you MUST restart your computer
also you can manually update your phone
http://talk.sonyericsson.com/message/139700#139700
Not applicable
Thanks. I will give this a go and get back. Thanx for the quick reply Slightly_smiling_Face
Anytime
Not applicable
Cheers buddy! The link has updated the phone. Just waiting now for it to boot up lol.
Fingers crossed
it should work, if it didn't or if you want to debrand or if you want EXTRA internal space for your apps check this link
Not applicable
Mate it has worked an absolute treat!
Thank You soo much! Like xmas all over again!
steve
Excellent Slightly_smiling_Face
