My Xperia x10 mini won't turn at al.. :(
Not applicable
I hav read all the comments on the same problem & i hav tried everything that was said BUT my x10 still won't switch on... Last nyt.. It just switched off after i sent a text msg.. & it was fully charged.. Tried switchin' it on... Wudn't go on.. Put it on charge, wudn't charge. I even connected it to the PC, tried the repair thing, it wudn't detect my phone. I dnt knw wat more to do to get it to go on.. Can any1 HELP plz???? Thanx..* Slightly_smiling_Face
11 REPLIES 11
Not applicable
Read my last post here, i think you have the same problem but unless you have the knowledge and equipment then you will have to take it to the dealer to get itrepaired.
http://talk.sonyericsson.com/message/9231#9231
Not applicable
forgive me for my bad english because iam from egypt,i tried every  thing to fix this problem in my sony ericsson xperia x10 mini pro mobile and failed many times but now i found the solution and it is:
it is software errors so update your software by sony ericsson pc companion and if you have the latest software version already,update it also routinely all the errors and this error will be fixed.do it by connect your phone to computer after set up sony ericsson pc companion and do update your phone and follow the instructions exactly till end and before update do factory data reset on mobile by enter settings on mobile then privacy then factory data reset then after the factory data reset done,do the update as i mentioned above and all the errors and problems will be solved insha allah and your problem will be solved insha allah.do back up before this steps because all information on your mobile will be removed.
thanks
