malfunction on my xperia arc s's screen
Not applicable
on every time I connect my phone to my PC, why does the screen keep on opening some applications. I have known that when every time my usb cable connects or even touches my phones usb port it starts to do something. and besides that i can't touch the screen. how can I solve this problem? and do I need to bring it to SE?
1 ACCEPTED SOLUTION
slimshaddy
Hero
if the update also doesn't helps , get it checked by a service centre near you..
mark correct and helpful answrs..
7 REPLIES 7
Not applicable
oh i nearly forgot. and when I sometimes touch my phone even it is connected to my computer and it is on a flat surface (not holding the phone i'm just only touching the phones screen when its on a flat surface table) the same problem occurs.
hope i'll have a quick reply.
slimshaddy
Hero
well the problem can be your computer Slightly_smiling_Face
i had the same issue , but checking on other computer i got to know that my pc was the culprit..
so just try to connect with a different computer..
slimshaddy
Hero
check with 2 more computers just to be sure...
if it behaves the same...
update your phone with this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this is an official sony software so don't worry..
and if it says your phone is up-to-date click on install anyway..
this will delete all the phone's data so backup all your files first..
how to backup..!!
download any one of the file on your computer . ( if you download this directly on your phone , it will be easy , if not then download on your computer )
http://forum.xda-developers.com/showthread.php?t=1193802
http://www.mediafire.com/?78bcyp5alpwy0ok
after downloading it , follow these steps
http://talk.sonyericsson.com/message/130376#130376 from step 2 onwards..
slimshaddy
Hero
Not applicable
thanks man, now i have some idea for it Slightly_smiling_Face
slimshaddy
Hero
hmm your welcome..
let me know if it works Slightly_smiling_Face
Not applicable
yes yes .. Slightly_smiling_Face
