Hey all.
Using SE Xperia Pro. Tried to update w/ Win 7 64 bit.
First Sony PC Companion wouldn't upgrade to newest version. I eventually got the new one, V. 2.10.027 (the blue windows shortcut icons, not the old green ones). When I attempt to upgrade the phone I get the dreaded "close wininit.exe" error. Nothing seems to resolve this.
Thanks for any help.
I'd really love to update the phone, recently (last 2 days) it's going crazy giving me the "you've got a text message" alert sound whenever it now attempts to connect to my home network server, you know, despite me triyng to always keep WiFi turned off.
Thanks,
Amar
Solved! Go to Solution.
update your phone with this
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
or
Thank you for the quick reply! This update service seems to be for the AINO (a phone which I no longer use). Is this the same program to use for the newer SE phones too?
Thanks
yeah buddy
go ahead, install it and you will come to know yourself
and remember to post the results
thanks so much, this did the job!!
