Help my xperia x8 have trouble
Not applicable
my xperia x8 is turning on automaticly and never been off, while in standby. please help me!
1 ACCEPTED SOLUTION
you probably unlocked the screen and it launch and app or you might be pressing the power/home button so it stays on
12 REPLIES 12
slimshaddy
Hero
it turns on automaticaly..? and you want your phone to be switched off.?? thats strange...
it happens all the time..?
remove the battery for some time then reinsert it..and see if the phone starts itself or not..
Not applicable
Yes its turns on automaticaly i dont know why, sometimes its turning on and off blinking in a sencond, while charging. I switch off my phone by pressing the on/off key its working properlly shotdown.
The worst problem is in the standby mode,  I try to remove battery, restart my phone but its not work it!
slimshaddy
Hero
backup your important files..
and update your phone with this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this will delete all phone's data so backup your files before updating..
update your phone and see if the problem persists..
slimshaddy
Hero
ok just to be sure./.
is your screen turning on or the phone itself..??
Not applicable
Yes automaticaly turns on! then the light never off. The all system of phone is proper funcionally, the lights is the only problem.
slimshaddy
Hero
ok update your phone and see if the problem persists..
Markus1
Leader
If you connect the charger when the phone is turned off it will "semi-start". It should not start in normal mode but in a charging mode just displaying a battery icon. Is this what's happening?
If you're having any problems with reboots you should update or repair the software with PC Companion.
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/pccompanion/xperiax8?cc=gb&lc...
Not applicable
Im incounter my phone is heated 2 times in my pocket, why my phone doing that?
