- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
The screen has totally froze no movement at all.Like a white background with millions of different dot colours.
Reminds be abit of fuzzy on TV but still
Tried switching on/off remove battery etc but still same
Any ideas?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can try Update Service to repair your phone
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
know that it will delete everything on your phone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
take the battery out, and w/o the battery press and hold the Power button for few seconds, then try again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you for your swift reply.
I have done that just but sadly the problem still exists....its like a mosiac filling the whole screen.
One minute the phone was working the next complete blank out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
for future reference
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the same issue on my experia play, and none of the mentioned here fixes are working for me just a ststic, fuzzy screen. Dose any one have any more ideas on how to get the display up and running again?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it might be a hardware problem more than a software glitch
if you want to contact SE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So this is for anyone that has this problem and seeks out help like I did. I was playing around with my phone while looking up ways to fix its static screen and stuff. I fixed it by holding down the power button for a moment until i knew the screen would normally have the phone options onscreen, then i just tapped the screen attempting to hit where these options would be and when i hit one, i think it was "silent mode" my screen flashed back to normal. I hope this can help someone with this terrifying problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ wrote:So this is for anyone that has this problem and seeks out help like I did. I was playing around with my phone while looking up ways to fix its static screen and stuff. I fixed it by holding down the power button for a moment until i knew the screen would normally have the phone options onscreen, then i just tapped the screen attempting to hit where these options would be and when i hit one, i think it was "silent mode" my screen flashed back to normal. I hope this can help someone with this terrifying problem.
This is many many years later but this worked wonderfully for my old Xperia Play that I'm nostalgic towards. Thank you! You're a gentleman and a scholar
