anuluj
Pokazywanie wyników dla
Zamiast tego wyszukaj
Czy miało to oznaczać:
vgn-fw21e and WiFi 802.11n
profile.country.pl_PL.title
wasylprv
Początkujący
I'm looking for any tips how to use my Vaio vgn-fw21e connected via Wifi to linksys WAG160 at the full speed using 802.11n standadr and not only 802.11g. The router is located couple meeters (2-3) from Vaio, no walls etc in between and seams that Windows connection property indicates the speed at the level of 54MB/s only. I've switch off the IP6 (i've heard Vista had some problems with that) and no effect. I though there is anything in BIOS od WiFi driver to be enabled - and ... nothng.
The router is set up for n standard with dual band 2.4 and 5 GhZ and wide channel.
Any idea how to speed up that stuff and get over full 802.11n speed?  I'd appreciate any help.
1 ODPOWIEDŹ 1
michal3411
Początkujący
Sorry , but only 802.11g is supported .
Try replace wi-fi card " N " standard supporting .
Message was edited by: michal3411
