Solved! Go to Solution.
Hi @Laavanya
Please, boot your device into safe mode as explained here. If this issue is not present in this mode, that indicates a third party app is causing the problem. In this case exit Safe Mode and then un-install any third party apps you don't need and clear the cache/data for the apps you want to keep. I´m at disposal for any question.
Hi @Laavanya
