Hi, i just bought xperia m2 dual a days ago and then i update the system. After updating to 4.4.4, the auto brightness doesn't work. Before updating the system, the auto brightness seems to work, that is at android 4.3. Is there any solution to this? Thank You
Solved! Go to Solution.
It'll be wise to reinstall the latest update with
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Check the Ambient light sensor, By performing Sony service test. Dial *#*#7378423#*#*
The proximity sensor and the ambient light sensor is working when i tested it using service test. The proximity sensor detect my hand when i put it on it. The ambient light sensor also giving different value when i put it at different lighting. But the auto brightness still not work.
Bridge (for Mac)
Wow it works, thanks
