Re: Detailed Software Repair Instructions using Pc Companion(Windows)or Bridge for MAC.(Update 8/10/
aviationgeek101
Visitor
So I own a 1 month old Xperia M. The screen stays black, however, I can sill see the glow from the back light. The Android OS runs perfectly underneath. It plays music, gives haptic feedback, etc. Do you think I should try this update? What if the screen STILL stays blank when I get till step 9? Please reply and help me with this dilema!!!:smileysad:
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
If the phone is one month old,and you did not damage your device,your warranty should be intact.
alexdon
5 REPLIES 5
_alexdon_
Post moved into correct section.My suggestion is to take the phone to a sony service,they will see if the problem is hardware,if not,they will update it for you.
alexdon
aviationgeek101
Visitor
Alright! I will visit the centre. I bought this just recently, but lost the invoice. Do you think my warranty is still covered without the invoice? If not, how much will they charge me?
_alexdon_
alexdon
aviationgeek101
Visitor
All right! Thanks!!:smileysmileywink:
_alexdon_
You are welcome,keep us updated.
alexdon
