problem with connexion USB ( MTP and MSC ) and pc companion
ilo
Visitor
Yesterday, I connected my smartphone on my pc for the first time (via USB cable)
My phone asks if I want to install PC Companion, I click Install.
Everything happens normally and I succeed in transfer my contacts from the PC to the smartphone.
I also did an update for the smartphone,
and since that time:
1 - PC Companion does not recognize my phone (in MTP or MSC mode)
2 - the phone will no longer charge via my PC in MTP mode (MSC mode the phone is charging!)
3 - USB icon appears when I connect my phone to the PC in MSC mode but not in MTP mode (though in MTP mode, when I go to Settings USB connectivity, my phone indicates that the USB cable is plugged in!)
I restored and rebooted the phone and the problems are the same.
Thank you for helping me.
1 ACCEPTED SOLUTION
ilo
Visitor
I think I managed to solve the problem :
You can try to enable or disable the USB debug option found under Development settings in the phone.
1 REPLY 1
ilo
Visitor
