Deel jouw ervaring!
how can I use the SD card to install Android apps (some as spotify request place to put music offline) and my internal memory is full ?
Sébastien
Opgelost! Ga naar oplossing.
I tested and it works for SPOTIFY.
Thank you, this is already better than before, though I had been hoping transfer more thing to SD card §
Sébastien
https://support.spotify.com/us/problems/#!/article/How-do-I-store-Spotify-on-my-SD-card
Check out here.I am not sure you will be let to store on SD.
I am sorry but at least it helps.
